  #21 (permalink)
Old 04-23-2007, 06:59 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
This is a general Alignment Spec's:
Front Suspension
Do It Yourself Alignment Article, click here
Front End Alignment Specs:
(GL) "Align it to 1 degree neg camber, 4 degrees pos caster, 0 toe. I am assuming you are using 17" tires. Tire pressures should be 23psi front and 27psi rear on a good gauge." - Solid axle car.
[FFR]:
Street Car:
3 degree caster : -1/2 degree camber : 1/16th degree total toe in.
Coupe and IRS Street Cars:
Front: Caster 3 : Camber -1 : Toe 1/16" Total
Rear: Camber -1 : Toe 1/16" Total
"Let's roll"
"Be part of Something Good
