Thread: Weekend Plans?
Old 04-23-2007, 04:07 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Sid, Did you try dropping the slave down to 5/8" diameter? You will get a better extension on the slave cylinder if you downsize the diameter 1 size from your 3/4"master cylinder. be sure it has a wrist pin to prevent over-extension.....easier than replacing a clutch.....if it works.....
