Is this something that just started happening, or has this been a problem since day 1 ?
Is the gas percolating in the bowls? That's what it sounds like. Do you have enough room between air cleaner and hood scoop to install a thick phenolic heat dissipation spacer under the carb? If not, try one of the metallic plates or a turkey pan.
http://store.summitracing.com/egnsea...115+4294814811
Warren
