Old 04-23-2007, 06:47 PM
hkelley's Avatar
hkelley hkelley is offline
Cobra Make, Engine: SPF #2101 Diamond Ed.; 460
Originally Posted by mrmustang
The 750CFM was too big a double pumper for your engine, the same goes for the 870cfm carb. A properly tuned 650cfm double pumper would be your best bet. Keep in mind that it can be as simple as adjusting the metering plates and jets once you have the proper size carb on the engine. Then it's a matter of balancing the timing and the carb adjustments until you get it just right.
Been there, done that countless times and learned a bunch from those experiences once I got time on a computerized chassis dyno.
Bill S.
Bill. Thanks. I am a bit hesitant to jump into another carb. If I have to I will but I really need to find someone local who can work on this thing. You planning on being in NC anytime soon?
