Old 04-23-2007, 07:00 PM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
mrmustang
Please explain the relationship between the carb size & the "flooding" problem.
I have a pro-system 4150xe-950HP on a 408W that is absolutely awsome.
Response is absolutely clean & crisp from idle on up.
I can drop the clutch at idle & it will smoke the tires if not controlled & i can cruise in traffic @ 1500RPM in 4th very nicely. I am definetely not a carb expert but it would seem the carb you are recomending would be a little small for a "460 with a big cam"
Craig
