Old 04-25-2007, 04:54 AM
DAVID GAGNARD's Avatar
Pete;
Had the same thing happen to me with my street car....one day it started up fine, but had a miss in it, I shut it down and checked everything, found that the terminals in the cap had some corrosion and I cleaned them,ran fine after that, did notice there was NO hole in the cap where the vent was supposed to be, so I drilled it out and now it is 100% better.... Both my caps have the brass terminals....
On another note; I was running the Ford Motorsport 8.5mm plug wires in both cars, I thought they ran just fine, then I bought a set of 8.5 mm MSD plug wires for the race car, as soon as I cranked it up the difference was noticable, started a lot faster and idled a lot smoother and the motor seemed smoother through out the power band.......
David
DAVID GAGNARD
