Old 04-25-2007, 11:13 AM
Murphy's Avatar
Murphy Murphy is offline
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Tools
You need a small mig welder to weld the brackets and tabs on the sidepipes. You have to fit the pipes to the car and motor, then weld. You can buy one for $100. You will regret not having a lift for the under car work. Of course it can be done but what a pain in the A$$. The home lifts are under 2K and well worth it. You can put it together in a weekend no problem.
