Old 04-25-2007, 12:39 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by John Owen
Some weight info for my blocks, weighed same day on same scale
Ford iron block from crate 521, including 2 bolt main caps
223 #
RDI 566 aluminum block with 4 bolt steel main caps
152 #
Hope the numbers are useful
Wow - only a 71 pound difference. I thought it would be significantly more than that. I guess for the expense, 71 pounds on a street car probably isn't worth it. Thanks for the great info. Does anyone know the difference in weight between a 351C with aluminum heads and a 460 with iron block and aluminum heads?
