Old 04-25-2007, 09:36 PM
RedBarchetta RedBarchetta is offline
Banned
Originally Posted by Calbullet
Dean, when you installed the brace, did you also install the Steeda differential bushings they sell?
Mel
No, just the brace. Note in the pic below that the brace just butts up to the rear bracket. They include a spacer with the brace, but you won't need it on the SPF rear end. Simple swap...unbolt existing bolts and bolt in the brace. Coaxing the thru-bolts on the rear bracket did take some manuevering of the pumpkin to get it all aligned perfectly...it's a very tight fit on my car (those two large bolts, that is).
Here's a shot of another mod that I performed prior. I was having clearance issues with the driver's side half shaft bottoming out on the frame. I'd get grease everywhere and would have to pull the half-shaft to fix the inner CV boot. Someone on SCOF gave me the idea (probably RT) of drilling new holes to effectively "raise" the differential in the frame. I measured carefully (see awe marks still on the bracket) and took it to a neighbor that had access to a machine shop with a drill press. Worked like a charm and ended up providing another 3/8" to 1/2" clearance that I needed.
-Dean
