Old 04-26-2007, 11:47 AM
Cobrabill's Avatar
Cobrabill Cobrabill is offline
Cobra Make, Engine: Superformance 427 Side-Oiler
Originally Posted by undy
I think I suggested that about 15 or so posts ago..
I don't think it's a carb problem. Your symtoms duplicate mine before I went to a return fuel system. With a single fuel line you're prone to pressure creep during low fuel demand. You might look at your fuel gauge and only see 6 psi.. What pressures aren't you seeing with the hood shut? Warmer temps will also aggravate the problem causing flooding more often.
Joe-do the return line.I don't buy the "hot fuel line" thing.Sounds like they are grabbing for straws. As for the sound,you'll hear it with the engine off.A combination of the pump & underhood temps COULD be causing a spike that pushes the needle off the seat.
MR Mustang-i can see your point.To a point.
PSSSSSSSS-my side-oiler(17 over) has a Braswell carb that started life as an 850CFM and is now just shy of 1000cfm.Absolutely flawless and returns about 17 mpg on a trip.( not that i give a rats ass about fuel milage,but an indicator of it's effeciency)
www.braswell.com
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
