Old 04-28-2007, 04:34 PM
4pipes's Avatar
4pipes 4pipes is offline
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Originally Posted by Jamo
Dave...true if you're using a solid roller cam and a bronze gear. Not just cold starts...the pump is running off the gear, and bronze just doesn't have the durability for that.
Pat and I had essentially the same motors, except for the dry sump on his motor. I blew bronze gears...he didn't.
That's why I finally changed over to a flat tappet.
Jamo, why is a bronze gear required with a solid roller, I never did understand that? Isn't the oil pump driven from the bottom of the distributor such that any gear material can be used with the cam interface?
BTW, I went to a flat tappet also when I had the engine detuned.
Dave
