Old 04-29-2007, 10:09 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
You won't need a vacume pump--your system just needs to be set up with the scavage capacity ratio to pressure pump volume and proper venting/breather balance between the engine and oil tank--there will be a pressure reduction in the crankcase as the scavage pumps will be pumping oil/air to the tank which must be vented and the crankcase needs to be vented/balanced to the tank, not to the atmospere
Aviaid makes very good products, they were the leader in the oil system modifications and everyone else copied them
Jerry
