Old 04-30-2007, 10:51 AM
RodKnock's Avatar
RodKnock RodKnock is offline
Morris, thank you. Questions.
Does the dry sump make the the breathing problem more acute than if I were to stay with wet sump? The reason I ask is that I think I had that same problem with my 540 BBC and I have a wet sump on that engine. I had to install two large K&N breathers one of each valve cover to help with the problem.
Is there a better setup than the Aviaid product?
Is the pump weeping problem due to venting or an inherent defect in the pump? Is there another pump on that market that works witht he Aviaid product and doesn't have any weeping issues?
Thank you again.
