Old 04-30-2007, 05:30 PM
tcrist tcrist is offline
JAC,
Looks like they sent you the same kit that they sent me. I was lucky. I did not have to cut my cross member. What did you use to bolt the upper A arm with? Mine came with a bolt an a Nylock nut. I figured that would be to hard for the alignment guy to deal with so I made my own T-nut to slide in the slots for adjustment, then added a lock washer to the bolt to lock everything together. If you want I can send you a print of the T-nut. I have a Classic Roadsters LTD from the early 90's. I am guessing that Don has changed a few things on the frame and all of this will work on new kits better.
Terry
