Old 05-01-2007, 12:29 PM
Durt's Avatar
Durt Durt is offline
Cobra Make, Engine: Superformance #243 - 351W stroked to 418
Originally Posted by Don McCain
Durt
1. What type rear end do you have? This basically dependent on the make car you have. The FFR car is based on a mustang straight axle on the rear. This type axle typically leaves the line better than an IRS car. The
IRS car takes some getting used to. Make several 1/8th
mile passes to get used to your starting line proceedure.
My year Superformance has an 8.8 Ford IRS as I recall. Most of my hard acceleration results in a pretty hard pull to the left. I don't know if this is just the torque demons twisting the car - but it could be the car isn't set up properly. All I know is, the "pucker factor" has definitely been present during rocket sled launches - hence the reason for my initial post.
