Old 05-01-2007, 01:15 PM
Velox Velox is offline
Cobra Make, Engine: SPF 545" stroked 460 - sold
Originally Posted by Madmiles442
The red drops are at the back of the Tremec trans, right at the U-joint.
Hi again, that's probably the rear trans seal (for the drive shaft yoke where it enters the rear trans housing) these can leak if there is wear on the yoke, like grooving seen with high mileage. You can remove your drive shaft fairly easily from below and pull out the yoke to inspect it. Main thing is make sure your trans fluid level is not low, check the level at the side fill plug. If the yoke is good and the seal is bad you can get another from Tremec or dealers like www.standardtransmission.com, just call them they know the part number. If you find the seal bad and don't want to mess with it most any transmission shop could replace it fairly easily. Have fun in Tulsa
