Old 05-02-2007, 05:56 PM
Automan Automan is offline
Default Rad Base Question
Hi Guys: I noticed on the AC rad base that holds the rad (off coarse) has two holes on either side. Is there anything that is suppose to be mounted there or does the rad just sit directly there? Not sure if i should put some kind of cushion there or with the A+C rad mounts supplied, that it can hold the rad there securely. Off course i would bolt or rivet the rad to the lip on the base. Let me know what you put between the rad and the base if anything.
Thanks
Automan
