Old 05-05-2007, 02:12 PM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
Badger, you're probably right (about the front of the scoop being a relative low pressure area - the base of the windshield is definitely a relative high pressure area), but someone should do a "tuft" test to check that out (tape 1 or 2 inch long pieces of yarn or string onto the leading edge of the scoop and watch it while driving to see which way air was going at the scoop). Obviously having a turkey pan with a hood seal would affect the results due to engine air flow, and I suspect that there are a whole lot of other variables that could affect it...whether the cooling fan was on, is the radiator sealed to the body, is the radiator upright, etc.
Ken
