Old 05-06-2007, 04:35 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
With all this discussion of the airflow or lack there of through the hood scoops does anyone know why the 289 comp cars almost always have a drilled aluminum plate at the front of the scoop? I really never noticed the difference in air flow until I was tuning my Webers, at idle with the hood up I could get the engine idiling at about 900-1000 rpm...then I drove it and needed to adjust one of the carbs, leaveing the engine idling, now at about 700 rpm, as soon as I opened the hood the idle increased about 200 rpm. And I don't have a "drilled plate" in front of my scoop. I never really experienced a difference in idle when I was running a 4-bbl...hood open or closed...with the Webers there is a big difference.
Just curious as to why this was done an the early comp cars? Especially if an open scoop reduces airflow...one partially blocked would seem to reduce it more.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
