Old 05-07-2007, 08:09 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Sid...Hey!..welcome aboard! You should be getting an email from Mid-Ohio with all their forms, releases, and a safety inspection form in a couple of days. These cover all the mandatory safety items for both you and your car. Some include...dual throttle return springs, no leaks...coolant, oil, etc, catch can for radiator overflow, recent brake fluid change (within two years), 5 or 6 point harness, roll bar, wheel bearing check, safety wired knockoffs (if equipped), no loose items in trunk, cockpit, or glove box, Snell 200 helmet, or better, adequate brake pads, and several others I can't think of just now.
A word of advice....a Motorcycle helmet is not - repeat not - sufficient for Mid-Ohio's requirements. Your helmet must be SNELL 2000 rated, at least. Most motorcycle helmets do not meet this requirement, but are DOT rated. The Snell Safety standard is pretty uniform for most sanctioning bodies, and fairly standard at most tracks and with event organizers. Here's a link to the Snell Foundation if you'd like more information http://www.smf.org/
Also, take a good look at your wheels. Mid-Ohio requires safety wired knock offs. Their safety inspection form is a self inspection, but you're subject to spot inspections once you're on Mid-Ohio's property.
Hope this helps... Lookin' forward to meeting you...!
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
