Old 05-08-2007, 06:08 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Start by draining the oil and removing the pan to see if any pieces fell into it. If you can't find them all, then my suggestion would to be pull then heads and see if you can flush out all passages. The other alternative and probably the safest one is to remove the engine and completely tear it down and clean everything. Even a tiny particle left in can cause major problems later on.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
