Thread: oil coolers
Old 05-10-2007, 12:06 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Generally speaking, if you're not running on the track, you probably don't really need a cooler. On the street, oil and water temps generally stay pretty close together. If you run a 180* thermostat on your 351W, you'll probably keep the oil temps below 200'ish.
Without a cooler, the temps will change rather slowly. Water temp may climb to 220* in slow traffic on a hot day. But once you get moving it will drop rather quickly. The oil temp won't respond as quickly without a cooler. During the summer I would run synthetic oil, because it can withstand heat spikes better.
