Old 05-10-2007, 06:09 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Originally Posted by Manowar
Leaking galley plugs at rear of block will produce such a leak. Trans and bellhousing must come off if the easy checks don't reveal it.
This was my problem with my 428FE. Thought it was the rear main, but after checking found the leak was higher. Had to pull everything, found one of the push in oil galley plugs was leaking. Pulled them all and then tapped the holes for brass plugs. Never had an issue after that, including at track events.
--Mike
