Thread: Global Warming
Old 05-10-2007, 10:08 AM
VRM's Avatar
VRM VRM is offline
Roughly 11.11% of an ice cube will be above the water level. This part of the ice is not displacing any of the water it is floating in.
This means that if you have a 100 litre ice cube (ok, really big drink!), then 11.11 litres of that ice cube will be floating above the level of the water.
Ice generally has a volume 9% greater than that of water, so roughly 1 litre of volume will be lost when the ice above the water level melts. Also roughly 8 litres of volume will be lost whn the ice below the water level melts. This leaves you with 2.11 litres of water to raise the level of your glass.
Steve
If you can't stay on the road, get off it!!
