Old 05-11-2007, 10:22 AM
shelby racer's Avatar
shelby racer shelby racer is offline
Cobra Make, Engine: Shelby CSX4788 with a Dawkins performance 490 ci iron genesis block hydrualic roller
Originally Posted by blykins
What bellhousing/trans did you use?
For instance, if you used a TKO with a Lakewood without using a short input or a spacer plate, you could have jammed the input shaft up into the butt-end of the crankshaft, which pushes the crank up against the thrust bearing. With enough force back there (pulling in with the trans bolts) you could really foul the crankshaft against the bearing.
When installing a new engine/trans (with aftermarket parts), you should always measure the input shaft length from the flange and compare it to how much room you have between the bellhousing flange and the end of the pilot bushing/bearing. You should also turn the engine over and make sure it turns as free as it did with no trans bolted to it. In addition to that, I usually knock the trans out of gear and insert a slip yoke into the trans. With it out of gear, you should be able to turn the engine over by hand and hold the slip yoke without much drag whatsoever.
It is a tremmac that was specially built for this car by some one that has enough expeience with trannies that SAI has has him do jobs for them and is in the process of developing a new tranny package forthem. It rolls around the shop just fine in neutral.
Racing, bull fighting and mountain climbing are the only true sports, everything else is just a game. - Hemmingway
