Old 05-11-2007, 10:01 AM
shelby racer's Avatar
shelby racer shelby racer is offline
Cobra Make, Engine: Shelby CSX4788 with a Dawkins performance 490 ci iron genesis block hydrualic roller
Default hydraulic slave / throw out bearing not working
Originally Posted by CHANMADD
When in nuetral the tranny and engine assembly are disconnected from the driveline.Try putting it in gear,get someone to sit in the car and depress the clutch,and see if the car still moves. Also try the same thing and see if the motor will turn with the clutch pushed in.
Unfortunately I can not get the hydraulic slave cylinder / throw out bearing to work which is the other part ("clutch") that I was originally trying to figure out. I get fluid to and from the master cylinder (hours to get at and removed / check and reinstall) but I may not be getting enough since I can not get the slave to bleed. Therefore putting the clutch in withthe car in gear does not allow it to move
Racing, bull fighting and mountain climbing are the only true sports, everything else is just a game. - Hemmingway
