Thread: Global Warming
  #47 (permalink)
Old 05-11-2007, 12:54 PM
Scott S's Avatar
Scott S Scott S is offline
Charter Club Cobra Member
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
I am still arguing Steve and Bo
http://van.physics.uiuc.edu/qa/listing.php?id=1650
http://www.physlink.com/education/AskExperts/ae389.cfm
Question
Assume there is an ice cube in a glass of water. When the ice cube melts, will the water level have risen, fallen, or remained the same? Why?
Asked by: Hugo Polichemi
Answer
Lets see now. Some intuitive center in my brain is screaming 'it will remain the same', but we will try to think it over.
In the first state, we have an ice cube of mass m floating in the water. If it is floating (in equilibrium), it will have to displace enough water to support its weight. How much is that? It is just Volume = m/d , where m is the mass of the ice cube, and d is the density of water.
In the second state, where the ice has melted, it turns into water of volume.... Volume = m/d! exactly the same volume as it displaced before. So the added volume is the same, so the level of the water will not change.
As a matter of fact, as long as objects are floating (i.e. they don't rest on the bottom) they displace enough water to support their mass. Since by turning from solid to liquid, the mass of water does not change (well, maybe it does, due to mass-energy equivalence, but that's _really_ negligible) it will keep displacing the same amount of water.
However, note that this may not apply to everything. If you had solid alcohol floating in water, when it melts, the level would drop, because water and alcohol mix at the molecular level; i.e. water filling spaces among alcohol molecules.
Answered by: Yasar Safkan, Ph.D., Sofware Engineer, Noktalar A.S., Istanbul, Turkey
Am I still wrong?
I love this stuff too.
Scott S
Working as hard as I can every day to double my carbon footprint.
