Help! - How Best To Access/Remove Clutch?
Per the other thread that I had posted, it appears that our ERA/FIA has a clutch problem. In order to access the clutch it looks like I will need to:
1 - Remove forward rollbar brace
2 - Remove seats
3 - Remove transmission tunnel
4 - Disconnect prop-shaft
5 - Unbolt trans from bellhousing
6 - Unbolt trans from mounts to car
7 - Try to slide trans toward rear of the car
Then - ? Do I need to lower the rear of the engine in order to pull the trans, or is there some secret to doing this that I don't have a clue about?
Thanks!!!
