Old 05-13-2007, 10:59 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
In regards to bleeding your clutch. Some slave cylinders will eitheer have the bleed nipple on the top or the bottom.If it is on the top thats easy as the air in the cylinder will naturally go to the top and out the nipple.If its on the bottom you will have to dismount the cylinder turn it so the the nipple is up,push the piston all the way in and open nipple.Just let the fluid run out without pumping the pedal and it should be good.close the nipple and remount it.
