Thread: Cold Blooded FE
Old 05-14-2007, 07:26 AM
601HP 601HP is offline
Bluedog,
I'm thinking like Commander. But, if the timing is correct, how strong is your spark?
Years ago I had a severe starting problem. Once while trying to determine what the problem was, I happened to have the hood up and was looking into the engine compartment while cranking the engine. I saw an arc jumping from the middle of the coil wire to a nearby metal bracket. That bugger was robbing most of the energy before it was getting to the plugs.
That pinhole in the coil wire was nearly invisible to the eye.
David
