Thread: Cold Blooded FE
Old 05-14-2007, 03:45 PM
Bluedog's Avatar
Bluedog Bluedog is offline
Cobra Make, Engine: Once Owned CSX4803, CSX803 block, Keith Craft 468, Suspension by Tom Barnard, Built by Kris Kincaid
Default Re: Follow-Up
Thanks for the suggestions so far! I've been going through a process of elimination trying to rule out the easy stuff. I sprayed just a little starter fluid into the 4 barrell and it started right up! Don't think it's a timing or spark issue from this test. Does the result suggest I'm not getting enough fuel into the carb? If so, you already know my next question, where do I increase the fuel mixture on a Holly 750?
Bluedog
