  #23 (permalink)
Old 05-15-2007, 04:45 PM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
Originally Posted by ENTDOC
I thought everone just drilled a hole through the regular or poly mounts and secured a bolt through it to limit movement. That method holds my 427so perfectly but dissipates vibration well , cheap too.
I thought about that first, but figured if I'm going to pull the mount to drill a hole and put in a bolt I might as well just get new mounts. It would have been much cheaper with buying two bolts though.
