Thread: Ford 289 vs 302
Old 05-22-2007, 08:31 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
I will look at several I have , but doubt that there is an easy visual clue. With the age of the engines, heads could get swapped,etc. Later 302s may be easily distinguished by some casting roughness or whatever, I don't know. I do know that you could not tell a 289 from a 302 in the late sixties when they were first released. You could pull a valve cover and see what it says under the cover, but as I said in the period that has passed since the 289 was last produced( 1968) a set of 302 heads could have been put on a 289 block. The casting # above the starter would tell you, but that is hardly a visual.
WDZ
