Old 05-23-2007, 08:13 AM
496fe 496fe is offline
A problem with many FE's is that the distributor hole in the manifold doesn't line up with the block hole. This might be causing the distributor to be bolted in cocked.
Try installing the distributor without the seal and see if it sits in the middle of the hole in the manifold. If it doesn't, you need to move the manifold or the hole to match.
Good luck,
Brian
