Old 06-01-2007, 09:46 AM
SJK2's Avatar
SJK2 SJK2 is offline
Cobra Make, Engine: SPF#2189
Originally Posted by blykins
Was it broken in on a dyno? If not, your rings may not be seated just yet....you could give it some good hard driving time and see what comes of it. Otherwise, it may be wise to do a compression check (also read your plugs) and see if you have a ring that's not doing its job.
Ok thanks will try all above, also it was run on a dyno so i "assume" broken in.....
Steve
