Old 06-03-2007, 05:46 AM
blykins blykins is offline
I would make the duration a little higher. A 224 duration isn't really much and I think it would make the peak too low for your desires.
In order to really do this job right, you need to compare the dynamic compression ratios of different cams that fit your needs. The static compression ratio really doesn't mean much. If you pick a cam with too much duration, your DCR will be low, and you'll actually lose power. Too little duration and your DCR will be higher than necessarily, which may compromise the use of pump gas.
Email me offline and I'll go through some engine sims and recommend some cams for you and your needs.
You want a roller cam, right?
