Old 06-03-2007, 12:37 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
You didn't state WHY you thought they were 6 cylinder spindles. I mention this because the 8 cyl spindles up until 1968 used the same 4 bolt mounting. The disc brake adapter( OEM) was attached to the 4 bolts much as you describe. They used 4 piston calipers in the early cars much like the Lincoln/T-bird calipers at the time, they may even have been the same. The forging # on the spindle will determine which it is. What you have described sound almost like the stock Disc brake option.
WDZ
