Old 06-03-2007, 06:02 PM
tamanaco's Avatar
tamanaco tamanaco is offline
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Originally Posted by Cashburn
What cable, spring kit, carb bracket, are you running? Also how is your cable routed? Is it catching on the carpet or simply the cable and/or springs binding? Also check the pivot rod of the pedal assembly to verify it is not too tight and binding there.
Don't know what cable, was assuming it was a BDR factory item? Car was assembled by Custom Cars. It looks like stainless steel braided something. The springs are big one on the outside and smaller inside. Carb bracket is a CSR 620 unit. Cable looks like it has nice curve from carb to the throttle bracket. The cable is not frayed from what I see exposed. it is not catching on floor mat or side carpet. Did notice that the s.s. braided tubing looks like its compressing/distorting at almost WOT?
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
