Old 06-05-2007, 11:15 AM
Dinobyte's Avatar
Dinobyte Dinobyte is offline
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
Well, after Dennis at Valley Ford Specialist took a look, he says oil is blowing out the dip stick, the seal of the manifold, the breather (and I have a PCV), and between the head and block. He thinks the rings never did set, and that the pressure in the crank case is causing all sorts of problems.
He is going to have to pull the motor and basically rebuild it correctly.
The drama continues.
