Old 06-05-2007, 04:21 PM
BMK's Avatar
BMK BMK is offline
Tongue Pirate
Hyde,
I will print this all off prior to the September departure. Will take a drive up there. I'll make sure I have a navigation system this time as I'll have a little spare time to get lost..
There are a few hills around here that test my 23 gear and I find that I really struggle on some of them with respiratory issues - it's the Lac. acid threshold that kills me.
I like you try and use the higher gears each run. Starting with the 23 and going down to 21 then 19 and keeping the revs/cadence up above 75..
Maybe I need to watch that TDR France stage with Floyd again, to see how it's done.
Will watch with interest - with his result/finding out soon.
Did you see that the designer of the test equipment basically said that the French lab. had no idea how to use the equipment correctly and they did not following procedures correctlty with his B sample etc.
Mmmm.
Thanks again with you help and advice on September.
Bernie
Bernie Knight
