Old 06-05-2007, 07:10 PM
MacGyver's Avatar
MacGyver MacGyver is offline
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
I went through the same thing when I first bought mine. The rings release from the bottom. You can use your fingers depending on how tight they are or a plastic pry tool gently pulling it out at the bottom then lifting when the bottom releases. It should be straight forward from there. Matt
