Old 06-06-2007, 04:28 AM
jerry w's Avatar
jerry w jerry w is offline
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
I used 3/8 rod. My bumpers are from Finishline. I put teflon tape (bumper end) on some of the ends of the threaded rod and I put medium strength Loc-tite on the others as an experiment to see which would hold better.
After a couple hundred miles no reported problems, both seem nice, tight and secure.
Regarding the oversize holes in the frame. I found that I had to adjust the angle of my bumpers ever so slightly to make them look even. I did this by sanding the end of a tube at just a little angle. The end of the tube that touches the frame. The over-size hole I think helped let the threaded rod line up where I wanted it. The tube is much larger in diameter than rod, so this allows for adjustment, which I needed.
Hope this helps, keep us posted.
Regards,
Jerry
