Old 06-06-2007, 06:00 PM
Backdraft Backdraft is offline
Cobra Make, Engine: BDR Roadster ,427 R
Hi there,
we do offer a xenon kit for our cars , it can be found at www.backdraftparts.com. The kit improves your driving beams but you do loose your high beams. The customers who have installed the kits really like them.
As far as the shifter goes, a mid shift kit is available for your transmission. This is not a simple bolt on kit and requires the transmission to be pulled apart to be fitted. The easier solution would be to turn the shifter around. This is something that can be done on the newer TKO 500's and 600's. It moves the shift leaver location about 3 inches forward and you will probably find a bigger shift boot to cover the hole rather than having to close it up and recarpet the car. You can then install a shorter lever and you will probably feel more at home in the car.
Regards Reg Dodd
www.Backdraftracing.com
