Old 06-09-2007, 01:34 PM
Automan Automan is offline
Default Adjusting my front coil overs.
Hi Guys: Ok, i am still having the same problem with my front driverside shocks. I adjusted the coil spring itself by turning if a few rounds. It did lift the car up but it still stays down after i apply pressure on the fender. It doesn't bounce back untill i get to about a 1/2 inch clearance of the tire. At that point there is alittle bounce but it doesn't return to the origional hieght until i lift it manually by the fender. So i went to theadjustable knob at the base of the shock. There are numbers there. So i tried adjusting it all the way to one end but it continues spinning. Tried the other way and it also continues spinning. What numbers did you use on your set up? What is the purpose of this knob.
Thanks
Automan
