Old 06-10-2007, 05:56 AM
cwmcobra's Avatar
cwmcobra cwmcobra is offline
Default Flywheel?
Byron,
What flywheel are you using? Robb will ask you to measure the depth of the ring gear from the block plate to determine which pinion to install. He has two; a standard and a short pinion. After measuring mine we determined I needed a short pinion and found the reason was a recess machined on the back of my flywheel where it mounts to the crankshaft. I'm using the Ford Racing M-6375-Z460 flywheel that is actually made by McLeod. I ordered a replacement ring gear from McLeod through Summit and installed it myself. Now that I have confidence in the alignment, I expect this combo to last a long time.
I have a short summary of my investigation that I shared with Robb to confirm proper alignment in PDF form. Email me and I'll send it to you if you like.
I think you will be impressed with Robb if you talk with him. He's not only a very knowledgable guy on starters, but he's motorhead racer also. Hope this helps.
Chuck
