Old 06-11-2007, 06:42 AM
sexzsn8k sexzsn8k is offline
Cobra Make, Engine: ERA #624 (427 S/C), 428 PI
Default FE Valve Adjustment Question
I was wondering if any of you FE guys out there had a cool way of setting the valve lash on the FE's. I have a 428PI with a custom Comp cam with flat tappet/hydraulic lifters and roller rockers with the ARP adjusters. I want to do this as a "STATIC" adjustment as it gets kinda messy with the motor running. It is also very hard to lock the ARP adjusters, especially as I am getting older and don't see as well as I used to, so I keep hitting my forehead with the allen wrench. It would seem easier to do it one head at a time and let the engine run in-between to re-pump up the lifters before doing the other side so you don't get to much bleed off. Any suggestions ?
If you want manners, drive something else....
COBRA's are ALL about EXCESS !
