Old 06-12-2007, 09:58 AM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
Default Differences in Lucas Wiper Motors
Ok... This is for all the guys out there who have the insatiable need to sweat the small stuff like I tend to do.
The original Shelby Cobra used a Lucas 75311 DR3 with a 120 degree gear, or so I am told. This is a two speed motor, 6-wire motor. The cheapest I can find is about $200 + a $200 core charge...
As I understand things, an alternative is to use an MG/Triumph Lucas motor and that the drive gear can may need to be changed or modified (as elegantly described in the ERA manual). I realize that these could be DR2 motors that are single speed and therefore 3-wire but visually pretty much the same as a DR3.
That being said what is the significance of the '75311' portion of the part number and what does it practically mean? Drive gear and/or degrees?
The reason I ask is that Land Rovers use a DR3 75664J and are reasonably priced and I would not need the all elusive core. I understand it may need a drive gear change or modification but it is two speed and would be visual and functionally corect...
I know to some this might be splitting hairs but I know to others out there that this stuff is... well... important.
Anyone... Anyone... Anyone...
-John
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
