Old 06-13-2007, 01:21 PM
Lowell W Lowell W is offline
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Freddie,
However you go about it, you want to hold or support the hub FLANGE (the part where the lugs go through) rather than the carrier itself. If you don't have a puller, this would be a good excuse to buy one...
Or, if you take the whole assembly off and put it in the hydraulic press, set the flange on a couple of heavy steel bars and press on the end of the axle.
Lowell
