Old 06-14-2007, 10:57 AM
jerry w's Avatar
jerry w jerry w is offline
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Sam,
since the gauges moved to the right, sounds like the polarity is correct. I would check to see if you have the correct sending units connected to the correct gauges. All gauges just measure current flow (ammmeters) correlated to a scale that represents another unit. (temp) The meters may have been damaged when the wrong strength signal from a sender was sent to the unit that could not handle the current being measured.
Good luck, keep us posted.
Regards,
Jerry
