Old 06-14-2007, 09:11 PM
berzerko's Avatar
berzerko berzerko is offline
Cobra Make, Engine: hurricane 1075
I'm building a hurricane using a aluminum 4.6 dohc out of a 03 lincon aviator mated to a 98 t45 trans so far so good It is tight since these are so damn big
I decided to go with a carburated set up from sullivan performance utilizing a msd ignition to run the stock coil over plugs.
I wanted to build something that will make people scratch their heads when they look at it the engine should be good for about 320 -340 at the crank with the car weighing in somewhere around 2500lbs wet
I can say nothing on these motors are cheap and unless you have forged internals do not push beyond 400 hp
Kar-kraft seem to offer a good package on 4.6 dohc's but since the motors are so tall height will be an issue
Good luck Bobby
